jarodsmith
Sep 29, 2015Aspirant
ReadyNAS Pro 6 web admin and data inaccessible
I have a ReadyNAS Pro 6 that began acting oddly as it would not display drives within the web admin, showed no volume, and would not allow the shares to be accessed across the network via Windows net...
- Sep 29, 2015
/usr/local/crashplan is using 3.3GB of the 4GB OS partition.
It is important that you configure things you install to store as much as possible on the data volume. Otherwise as has happened here you can easily fill the OS partition.
mdgm-ntgr
Sep 29, 2015NETGEAR Employee Retired
Could be a full 4GB OS partition.
What services are you running?
What add-ons do you have installed?
mdgm-ntgr
- jarodsmithSep 29, 2015Aspirant
Can the service be stopped, that file relocated to the data volume, the configuration be edited to indicate the new location, and the service be started again?
or .. worse case, the service stopped and the file deleted?
