jarodsmith
Sep 29, 2015Aspirant
ReadyNAS Pro 6 web admin and data inaccessible
I have a ReadyNAS Pro 6 that began acting oddly as it would not display drives within the web admin, showed no volume, and would not allow the shares to be accessed across the network via Windows net...
- Sep 29, 2015
/usr/local/crashplan is using 3.3GB of the 4GB OS partition.
It is important that you configure things you install to store as much as possible on the data volume. Otherwise as has happened here you can easily fill the OS partition.
mdgm-ntgr
Sep 29, 2015NETGEAR Employee Retired
jarodsmith
Can the service be stopped, that file relocated to the data volume, the configuration be edited to indicate the new location, and the service be started again?
or .. worse case, the service stopped and the file deleted?
- mdgm-ntgrSep 29, 2015NETGEAR Employee Retired
I have followed up with you via PM.
- hooperOct 05, 2015Aspirant
Same exact freaking issue here with crashplan. Can you please share the answer with the community. My guess is this will come up again.
Thanks.
- StephenBOct 05, 2015Guru - Experienced User
Thanks.
Maybe look here: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/td-p/985781
If you have ssh access, then go to /usr/local/crashplan/upgrade and delete the upgrade files.
rm -rf 1*.* will do that.
