linkup1
May 30, 2016Aspirant
ReadyNAS Pro Biz Edition upgrade from 6X2TB to ?
I have a 2009 ReadyNAS Pro Biz Edition that has six 2TB drives and it is running RAIDiator 4.2.22. I haven't had it on for awhile and quit using it because it filled up. I have a couple 3TB drives ...
- Jun 19, 2016
linkup1 wrote:
Still not getting the math. at 14TB I already subtracted a full 4TB drive for redundancy. Then what is the additional 1.3TB being taken away?
14 TB and 12.7 TiB are the same amount of actual space, just reported using different units. Drive manufacturers always use TB. The NAS uses TiB, but calls it TB (as does Windows).
1 TB = 1000*1000*1000*1000 bytes
1 TiB = 1024*1024*1024*1024 bytes
To convert 14 TB to TiB, the formula is
14*(1000/1024)*(1000/1024)*(1000/1024)*(1000/1024) = 12.7 TiB.
There are similar mismatches for GB /GiB and MB/MiB.
Retired_Member
Jun 17, 2016Ok. I presume, that's the way you calculated the overall capacity.
4+4+3+3+2+2-4=14
You counted 4TB of overall parity.
From these 14TB, you need to count (or I should say substract), the TB vs TiB "bs", the few GB per HDD used for os and swap, the overhead due to filesystem format.
Could you post your mdstat from the logs to see where you're at in the resync/build? Or PM to me?
4+4+3+3+2+2-4=14
