linkup1
May 30, 2016Aspirant
ReadyNAS Pro Biz Edition upgrade from 6X2TB to ?
I have a 2009 ReadyNAS Pro Biz Edition that has six 2TB drives and it is running RAIDiator 4.2.22. I haven't had it on for awhile and quit using it because it filled up. I have a couple 3TB drives ...
- Jun 19, 2016
linkup1 wrote:
Still not getting the math. at 14TB I already subtracted a full 4TB drive for redundancy. Then what is the additional 1.3TB being taken away?
14 TB and 12.7 TiB are the same amount of actual space, just reported using different units. Drive manufacturers always use TB. The NAS uses TiB, but calls it TB (as does Windows).
1 TB = 1000*1000*1000*1000 bytes
1 TiB = 1024*1024*1024*1024 bytes
To convert 14 TB to TiB, the formula is
14*(1000/1024)*(1000/1024)*(1000/1024)*(1000/1024) = 12.7 TiB.
There are similar mismatches for GB /GiB and MB/MiB.
Retired_Member
Jun 17, 2016So, vertical expansion.
Then yes. All the RAIDs must be resync before the last RAID1 is created.
linkup1
Jun 17, 2016Aspirant
Gotcha....it jumped from 16 hours to 3 hours, 21% to go, no drive failures yet. Will see what it says when done.
Thanks again to both of you!
