sylvainp
Nov 25, 2019Aspirant
ReadyNas Pro business Edition - How to install SSD and use Tier
Hi all, I have a ReadyNas Pro Business Edition (6 bays) I upgrade the CPU and RAM. At the moment I use the NAS as a Core for Roon and I would like to use a SSD for tier to store all the Roon Metadata...
- Nov 27, 2019
Sandshark wrote:
While that is plenty fast enough to keep up with sustained transfer from hard drives, it's not going to push an SSD to it's max speed. About half for most, in fact. So, before you invest in this plan, you need to assess how much speed you will actually gain.
I agree.
SSDs don't have any seek time, so if you have a lot of files than either an SSD array or ReadyTier should significantly improve folder browsing.
Large file transfers are already limited by the gigabit ethernet speed (which is lower than SATA 2), so you won't see any improvement with them.
Nov 25, 2019Guru - Experienced User
sylvainp wrote:
The HDD holder only have the holes for 3.5 HDD but the HDD tray holder has alot of big holes for ventilation.
Anyone have install a SDD on these HDD tray holder, and how ?
I haven't, but I did take a look at possible inserts a while ago. Most are designed to handle 2 SSDs in an single 3.5" bay - which I don't think would line up the SATA connectors properly. Perhaps someone else here has a suggestion.
sylvainp wrote:
What would be the best way to make SSD tier. Starting all over or just add SSD and deactivate X-RAID ?
Switching the FlexRAID is the most direct way to do it. You'd do that before you added the SSD.
sylvainp wrote:
For SSD tiering can we just use 1 SSD or it's better to use 2 ?
Two. It's not a cache, so if the SSD(s) fail you will lose the volume. Perhaps also consider replacing one SSD about half-way through it's lifetime, so you don't hit the wear-level thresholds on both at the same time.
If I use the Flex-Raid with Tier SSD can I expand the volume of the 2 x 3TB later or it's a 1 shot thing ?
You can still expand the mechanical disk array both horizontally and vertically with flexraid.
FWIW, you always need a backup plan in place to keep your data safe - but I think that is even more important when you use these more sophisticated RAID modes in the NAS.
- sylvainpNov 25, 2019Aspirant
Thank you for the explanation. I will have to find a way to attach the SSD in the HDD drive cage first.
As for backup I have a external 8TB USB drive which I make a backup of all my share folders once in a while with the ReadyNAS backup features which is a bit slow but it's working.
- SandsharkNov 26, 2019Sensei
You're going to need somethng that's specifically designed for servers. the problem is, most of them only have side-mount holes and the legacy NAS caddies only have bottom holes. Neither Dell nor Supermicro ones will work. There are a couple varieties of HP adapters that look like they will, but they tend to be expensive. I just took a quick look at eBay with a search of "server 3.2 to 2.5" and "HP 3.5 to 2.5" there are some for sale at a reasonable price that should work.
- SandsharkNov 27, 2019Sensei
I got to thinking about this after I responded. The Pro BE (and all derivatives of that motherboard) has an Intel ACH8 family SATA controller, which is only SATA 2.0 (3Gb/sec.). While that is plenty fast enough to keep up with sustained transfer from hard drives, it's not going to push an SSD to it's max speed. About half for most, in fact. So, before you invest in this plan, you need to assess how much speed you will actually gain.
And if you decide to go on, don't waste money on the fastest SSD you can find.
The specs I have found for all the systems that originally ran RAIDiator 4.2.x say Serial ATA-300 (aka SATA 2.0). It makes sense for the time frame of their release (at least for most of them) but I don't know if that was an OS limitation or true of all the hardware. I have run lspci on a Pro6 and can say without reservation that it has the above controller with the hardware limitation.
