DownloaderUK
Sep 03, 2016Aspirant
ReadyNAS Pro Business Edition - No folder in SSH
Hi all, Newbie here. I have accessed my unit via SSH and this is all l can see Root Directory There are no visible directories present! I am using the commands ls -als. This is the p...
bedlam1
Sep 03, 2016Prodigy
Try the command cd //
Then look again
Just as an observation I see you are running Radiator 4.2.28, have you considered upgrading to the latest firmware OS 6 (backup all your data first)
Some info here http://netgear.nas-central.org/wiki/OS6_on_Legacy_x86
- BrianL2Sep 05, 2016NETGEAR Employee Retired
Hi DownloaderUK,
Can you try the command "cd /" (without the parenthesis) and see if it will list the directories under root.
Kind regards,
BrianL
NETGEAR Community Team - JennCSep 09, 2016NETGEAR Employee Retired
Hi DownloaderUK,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
