DownloaderUK
Sep 03, 2016Aspirant
ReadyNAS Pro Business Edition - No folder in SSH
Hi all, Newbie here. I have accessed my unit via SSH and this is all l can see Root Directory There are no visible directories present! I am using the commands ls -als. This is the p...
bedlam1
Sep 03, 2016Prodigy
Try the command cd //
Then look again
Just as an observation I see you are running Radiator 4.2.28, have you considered upgrading to the latest firmware OS 6 (backup all your data first)
Some info here http://netgear.nas-central.org/wiki/OS6_on_Legacy_x86
BrianL2
Sep 05, 2016NETGEAR Employee Retired
Hi DownloaderUK,
Can you try the command "cd /" (without the parenthesis) and see if it will list the directories under root.
Kind regards,
BrianL
NETGEAR Community Team
