fishnchips
Apr 06, 2013Aspirant
ReadyNAS Pro Lost Volumes on Disk replacement
Hi all. Slight panic stations here. I have a ReadyNAS Pro (latest firmware - 4.2.22) which had 6 Samsung HD204UI 2TB drives. I swapped one out for a new WD WD30EFRX 'NASWare' WD Red 3TB drive. It rebu...
Apr 06, 2013Guru - Experienced User
Try rebooting using the front panel option to skip the volume check.
