fishnchips
Apr 06, 2013Aspirant
ReadyNAS Pro Lost Volumes on Disk replacement
Hi all. Slight panic stations here. I have a ReadyNAS Pro (latest firmware - 4.2.22) which had 6 Samsung HD204UI 2TB drives. I swapped one out for a new WD WD30EFRX 'NASWare' WD Red 3TB drive. It rebu...
fishnchips
Thanks for the response. That didn't fix it.....
Severity Date Message
Sat Apr 6 23:47:17 WEST 2013 System is up.
Sat Apr 6 23:46:57 WEST 2013 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. media webroot backup addons-config
