fishnchips
Apr 06, 2013Aspirant
ReadyNAS Pro Lost Volumes on Disk replacement
Hi all. Slight panic stations here. I have a ReadyNAS Pro (latest firmware - 4.2.22) which had 6 Samsung HD204UI 2TB drives. I swapped one out for a new WD WD30EFRX 'NASWare' WD Red 3TB drive. It rebu...
fishnchips
I stuck the old drive back in again and now at least the volume mounts although it just shows the 3Tb as dead rather than recognising the old 2TB drive. I'm going to try and find a spare 9TB somewhere to back stuff up before doing anything else!
Device Description Status
Disk 1 SAMSUNG HD204UI 1863 GB , 29 C / 84 F , Write-cache ON OK
Disk 2 SAMSUNG HD204UI 1863 GB , 29 C / 84 F , Write-cache ON OK
Disk 3 WDC WD30EFRX-68AX9N0 2794 GB , 20 C / 68 F Dead
Disk 4 SAMSUNG HD204UI 1863 GB , 29 C / 84 F , Write-cache ON OK
Disk 5 SAMSUNG HD204UI 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 6 SAMSUNG HD204UI 1863 GB , 30 C / 86 F , Write-cache ON OK
