digitalnegative
Jan 17, 2012Aspirant
ReadyNAS Pro Pioneer Not Accepting DHCP IP addresses
I've got a ReadyNAS Pro Pioneer that disappeared from my network in the middle of last week. I rebooted from the device's power button and when the device boots up it indicates that it has IP address...
digitalnegative
Jan 20, 2012Aspirant
mdgm wrote: If you connect the other NIC to your router/switch does that work fine? Or does it also have the same problem?
What version of RAIDiator?
Both NICs have the same problem.
Radiator 4.2.13 is installed.
Thanks,
Alan
