digitalnegative
Jan 17, 2012Aspirant
ReadyNAS Pro Pioneer Not Accepting DHCP IP addresses
I've got a ReadyNAS Pro Pioneer that disappeared from my network in the middle of last week. I rebooted from the device's power button and when the device boots up it indicates that it has IP address...
mdgm-ntgr
Jan 20, 2012NETGEAR Employee Retired
RAIDiator x86 4.2.13 is from August 2010: http://www.readynas.com/RAIDiator_x86_4_2_13_Notes
There is limited support for such old firmware.
Please update to RAIDiator x86 4.2.15: http://www.readynas.com/RAIDiator_x86_4_2_15_Notes and see if that makes a difference.
You could update to 4.2.16 but if you were to update to that you could not subsequently downgrade the firmware to 4.2.15 or earlier (so be aware of that if you wish to try that).
It is recommended that if you do wish to update to 4.2.16 or later that you update to 4.2.16 first then onto the later firmware.
