APcMini
Mar 29, 2012Aspirant
ReadyNAS Pro: Volume size of more than 13,6TB not possible?
Hi! I know it's not supported officially, but I bought four Hitachi 4TB 7K400 (HDS724040ALE640) and put them into my ReadyNAS Pro Business. I also got two WD 3TB (WD30EZRX) drives in this NAS. Afte...
dsm1212
Apr 04, 2012Apprentice
You've had 3 disks have a problem in that slot so it might be worth a support call to have netgear look at your system. Especially if the system is new and still under warranty. You could look at /var/log/messages to see if that drive showed any problems during the init which excluded it.
steve
steve
