miogpsrocks's avatar
Jun 30, 2018
Readynas seem kind of slow, How do I check volume, scan hard drive,etc.?
Firmware 6.9.2 Readynas Pro
4TB drives X 6 bays.
15% disk space free.
Thanks.
  • bedlam1's avatar
    bedlam1
    Jun 30, 2018
    You need to be on System/Volumes tab and double click the "Gearwheel" on the left
    • miogpsrocks's avatar
      miogpsrocks
      Tutor
      StephenB wrote:
      Try benchmarking the speed with Nastester: http://www.808.dk/?code-csharp-nas-performance
      There are several maintenance functions on the volume settings wheel (balance, disk test, scrub, and defrag).
      Are the maintenance functions such as balance, disk test, scrub and defrag part of the Nastester program or something that should be there already?
      I do not see these fuctions Xraid, format, global spare, new volume are teh only options I see.
      Please advice.
      • bedlam1's avatar
        bedlam1
        Prodigy
        You will find the maintenance functions if you click on the "gearwheel" shown in the box on the left of your screenshot
ProSupport for Business
