iamtheevster
Nov 14, 2015Aspirant
Readynas Ultra 2 - Raid is Dead
I have a Readynas Ultra 2 that's just over three years old. It's got two 3TB WD Red drives in it that are less than 6 months old (recently upgraded the drives). When I couldn't access the shares ...
- Nov 15, 2015
Likely this is your problem: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/985781#M10762
Do you still have ssh access to the NAS?
iamtheevster
Nov 15, 2015Aspirant
Okay. Any recommendations on what I can try/next steps to take?
iamtheevster
I reread the original linked posted on the problem with Crashplan and JRE version, so I'm starting there. I'm able to put the Readynas into tech support mode so that I can telnet into it, but I can't login. The default admin login/password isn't working, nor is the password for the admin account that I have set. Neither is the account I usually use to login via SSH (and that has sudo authority).
I've done some googling, but I've only come across other posts that say to google for the password, none that actually contain the password (except for the manual which has the default admin username/password that aren't working).
Is there a different telnet password? Where would I find it?
Thanks,
Evan
