tigermike74
Mar 27, 2015Aspirant
ReadyNAS Ultra 2 Fails after setup
I've had my ReadyNAS for about a year and have used it for about 5 hours total. I watched 2 movies on it, and an hour of setup/file transfer time. My wife decided it was time to clear out the DVD ca...
Makosx
May 02, 2015Aspirant
Hello!
I have a problem!!!
After Factory reset I start the Raidar 4.3.8. run the "Disktest"
test is OK (the led on tool-bar is green).
Click SETUP and choose Volume (X-RAID2) then push next.
Is in FW status show „Installing”, on the toolbar where show the VOLUME blinking the green LED and FW status show 21% (some times show 42%, 61% or 100%).
After a few seconds the Raidar panel show the „help” description. On the NAS light the act and Disk 1 LED, Disk 2 LED blinking.
I waited for several hours but not completed by the NAS and Raidar only shows the „help” section. This process also tried several times but it always ended the same.
The DHCP is see the ip address, dut I can't connect to the readynas Ultra 2
The HDD is HCL compatibille (Toshiba DT01ACA100)!
What can be wrong?
I have a problem!!!
What can be wrong?
