bbirkhahn
Aug 04, 2011Aspirant
ReadyNAS Ultra 2 Plus - Which fan is built in?
Hello! I'm looking for a silent replacement fan, which fan is built in? Thanks!
mangrove
Jun 20, 2012Apprentice
Chams_Dean wrote: You used a 4 pin connector ?
If you use the 3 pin, the noctua will run at full speed ( if you didn't add resistor cables) and should not need calibration ?
Nope, a three pin, the original is also a three-pin "normal" fan.
