dmgk
Jul 31, 2016Aspirant
ReadyNAS Ultra 2 Plus will not boot, corrupt firmware suspected but need help...
Hi, I read another posting "ReadyNAS Ultra 2 Plus can't find on Raidar/network" and I understand mdgm can help if you have corrupted boot wich I suspect. I did do some manual add of packages ...
omicron_persei8
Jul 31, 2016Luminary
Ok so there is a procedure for usb boot recovery on RAIDiator 4.2 ^^
If you did factory default and it still doesn't work, there might be an issue with the firmware package stored on the flash (the factory default extracts it on the HDDs). Is the NAS still under hardware warranty? You can check from your my.netgear.com account.
You should contact NETGEAR Support.
dmgk
unfortunately I think its like 3 years old or more, so I do not think there is still HW warranty?! :-(
- StephenBJul 31, 2016Guru - Experienced User
The hardware warranty is 3 years, so perhaps you should check the actual purchase date.
- dmgkJul 31, 2016AspirantHi, thanks. But after checking I see my memory is not so good, it was almost 4 years since I bought it :-( - Hardware Warranty: Expired on 08/Aug/2015 - Phone Support: 90 days -> 06/Nov/2012 - Email Support: 90 days -> 06/Nov/2012 - Chat Support: 90 days -> 06/Nov/2012 - Power Supply Warranty: Expired on 08/Aug/2015 - Accessories Warranty: Expired on 08/Aug/2015
- mdgm-ntgrJul 31, 2016NETGEAR Employee Retired
When you do USB Boot Recovery on a 4.2 system you may wipe the EEPROM adding an additional problem.
I have sent you a PM.
