dmgk
Jul 31, 2016Aspirant
ReadyNAS Ultra 2 Plus will not boot, corrupt firmware suspected but need help...
Hi, I read another posting "ReadyNAS Ultra 2 Plus can't find on Raidar/network" and I understand mdgm can help if you have corrupted boot wich I suspect. I did do some manual add of packages ...
dmgk
unfortunately I think its like 3 years old or more, so I do not think there is still HW warranty?! :-(
Jul 31, 2016Guru - Experienced User
The hardware warranty is 3 years, so perhaps you should check the actual purchase date.
- dmgkJul 31, 2016AspirantHi, thanks. But after checking I see my memory is not so good, it was almost 4 years since I bought it :-( - Hardware Warranty: Expired on 08/Aug/2015 - Phone Support: 90 days -> 06/Nov/2012 - Email Support: 90 days -> 06/Nov/2012 - Chat Support: 90 days -> 06/Nov/2012 - Power Supply Warranty: Expired on 08/Aug/2015 - Accessories Warranty: Expired on 08/Aug/2015
- mdgm-ntgrJul 31, 2016NETGEAR Employee Retired
When you do USB Boot Recovery on a 4.2 system you may wipe the EEPROM adding an additional problem.
I have sent you a PM.
- mdgm-ntgrAug 01, 2016NETGEAR Employee Retired
The firmware on the flash was corrupt.
Should now be fixed.
Please confirm.
- dmgkAug 02, 2016Aspirant
Hi,
It works!! Thanks a lot!!!!
Daniel
