mfawcett77
Jul 02, 2013Aspirant
ReadyNAS Ultra 2 reset?
Hopefully I can explain this clearly:) Have just bought the unit and installed a 3TB drive into it and started transferring over lot of files. Bought my 2nd drive the following week, same size and wis...
mdgm-ntgr
Jul 02, 2013NETGEAR Employee Retired
When you do the factory reset, you need to open RAIDar during the 10 minute countdown and setup the NAS to use Flex-RAID. Then if it setups a volume you don't want, delete that and create two RAID-0 volumes (one on each disk). Creating a separate volume on each disk is preferable as if one disk fails only the data on that disk is lost. If you have a single RAID-0 volume spanning both disks if either disk fails all data is lost.
