mfawcett77
Jul 02, 2013Aspirant
ReadyNAS Ultra 2 reset?
Hopefully I can explain this clearly:) Have just bought the unit and installed a 3TB drive into it and started transferring over lot of files. Bought my 2nd drive the following week, same size and wis...
mfawcett77
mdgm wrote: When you do the factory reset, you need to open RAIDar during the 10 minute countdown and setup the NAS to use Flex-RAID. Then if it setups a volume you don't want, delete that and create two RAID-0 volumes (one on each disk). Creating a separate volume on each disk is preferable as if one disk fails only the data on that disk is lost. If you have a single RAID-0 volume spanning both disks if either disk fails all data is lost.
That's the problem. I'm sure I'm resetting it correctly but when I get back into it, it won't even come up with that option to use Flex-RAID again for some reason. Just keeps going back to as if nothing had happened.
Powering down the unit, starting it up with reset button held in then pressing back up twice until disk 1 LED light comes on then pressing reset again. That seems to be the right way to do it after hours of research:) Does this sound correct or am I missing something? Cheers again.
