mfawcett77
Jul 02, 2013Aspirant
ReadyNAS Ultra 2 reset?
Hopefully I can explain this clearly:) Have just bought the unit and installed a 3TB drive into it and started transferring over lot of files. Bought my 2nd drive the following week, same size and wis...
mfawcett77
mdgm wrote: When you do the factory reset, you need to open RAIDar during the 10 minute countdown and setup the NAS to use Flex-RAID. Then if it setups a volume you don't want, delete that and create two RAID-0 volumes (one on each disk). Creating a separate volume on each disk is preferable as if one disk fails only the data on that disk is lost. If you have a single RAID-0 volume spanning both disks if either disk fails all data is lost.
Also, is there an actual physical timer that appears that says 10 minutes or just presumed 10 minute cycle? Because if so, definitely can't see one:)
