mfawcett77
Jul 02, 2013Aspirant
ReadyNAS Ultra 2 reset?
Hopefully I can explain this clearly:) Have just bought the unit and installed a 3TB drive into it and started transferring over lot of files. Bought my 2nd drive the following week, same size and wis...
mdgm-ntgr
Jul 03, 2013NETGEAR Employee Retired
Provided remote assistance via Teamviewer. The system was running old firmware, so mfawcett77 updated the system to 4.2.23 and we had another remote assistance session later. I determined the system was already running Flex-RAID with a single RAID 0 volume C using disk 1. So I showed how to create a second RAID 0 volume D on disk 2 (using the Add Volume button under Volumes in Frontview), and then once the volume had been created I pointed out that shares would need to be created via Shares in Frontview.
