theali3n
Jan 15, 2020Aspirant
Readynas Ultra 4 Plus no valid volume exists
I had a disk failiure on drive 3 which then rebuilt. Then I had a disk failure on drive 2 and my volumes are gone. I got another replacement, but something is not right and the array won't aut...
theali3n
Jan 19, 2020Aspirant
It was running latest firmware for this encloser/board. I haven't hacked at it at all.
Do you know if I can pay netgear for a support case and have them login remotely and take a look ? This would be the best option IMO.
I can try a ton of things, but raid recovery from PC would be "last resort" to get the content back. I already have another array, I just need to get this data back and move it over if I can get to it.
Jan 19, 2020Guru - Experienced User
As I posted earlier:
https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
You could explore with them the possibility of starting with per-incident support, but given the multiple disk failures they will almost certainly move straight to data recovery.
