ManiacMike
Feb 07, 2017Aspirant
ReadyNAS Ultra 4 "Volume scan found errors that it could not easily correct."
Hi all! First time poster, long time lurker. After years of happy use of the Ultra 4, I have my first (major) issue. None of the shares are mounting, presumably due to the missing volumes. Fur...
ManiacMike
Feb 08, 2017Aspirant
Excellent, I'm in as root and have been investigating. It seems that I keep circling around the following error:
EXT4-fs (dm-0): ext4_check_descriptors: Block bitmap for group 17216 not in group (block 623566614080)! EXT4-fs (dm-0): group descriptors corrupted!
I found a few descriptions of a similiar problem, each mildly horrifying and all fairly dated. Looks like I can pursue a few options
1) mke2fs - Seems the safest approach, any method to the madness?
2) Reboot without the volume check - Instructions say this is risky, but no reason given.
3) Mount with fuse and copy of the data to a new drive - All instructions point to use of ext2 which doesn't make sense to me.
4) Run fsck.ext4 - Seems I may lose data, but the disks didn't have any failures before....
5) ???
More info
# lvs
LV VG Attr LSize Origin Snap% Move Log Copy%
c c -wi-a- 3.85T
# pvs
PV VG Fmt Attr PSize PFree
/dev/md2 c lvm2 a- 685.12G 0
/dev/md3 c lvm2 a- 3.18T 5.00G
# mount /dev/c/c /c
mount: wrong fs type, bad option, bad superblock on /dev/c/c,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
# lvscan
ACTIVE '/dev/c/c' [3.85 TB] inherit
# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md3 : active raid5 sda6[0] sdc6[2] sdb6[1]
3418630528 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
md2 : active raid5 sda5[0] sdd5[3] sdc5[5] sdb5[4]
718431744 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid5 sda2[0] sdd2[3] sdc2[5] sdb2[4]
1572672 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sdc1[5] sdb1[4] sda1[0] sdd1[3]
4194292 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
Feb 09, 2017Guru - Experienced User
mke2fs creates a new file system, so I am puzzled why you'd want to do that. If you are ok with the data loss, a factory reset would be the next thing to try.
I'd probably try booting w/o the volume check next myself.
