Ado1
Oct 22, 2014Aspirant
ReadyNAS Ultra 6 /dev/md0 is 100%
Hi All,
First time poster, long time follower :D
My NAS rebooted and started a resync and after some investigation and trolling through the posts, I have discovered /dev/md0 is 100%
I have looked at / where its supposed to be mounted and I come up to a total of 500mb
I have excluded the link folders ( -> ) and "c"
The question is, where is the 4Gb odd being used up?
I can account for only 523 MB...
Any help would be appreciated...
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 4184756 4184756 0 100% /
tmpfs 16 0 16 0% /USB
/dev/c/c 8736443516 8377719924 358723592 96% /c
3.6M bin
608K dev
7.2M etc
14M frontview/
8.0K home/
4.0K initrd/
94M lib
2.2M lib64/
16K lost+found/
4.0K mnt/
4.9M opt/
0 proc/
672K ramfs/
40K root/
5.1M sbin/
0 sys/
3.1M tmp/
0 USB/
248M usr/
142M var/
0 0
523M total
- Ado1AspirantSo if I wait for the resync to finish, reboot, do some volume checks and if things are still strange, then do the os re-install, that would be a good plan?
- mdgm-ntgrNETGEAR Employee RetiredI would suggest you make sure you have an up to date backup before doing any volume checks if you want to do one of those.
- Ado1Aspirantright.... So now would be a good time to get another NAS ;)
- Ado1AspirantAlso, by volume checks I mean the items under the volume maintenance tab, i.e. disk scrubbing and consistency checks
- mdgm-ntgrNETGEAR Employee RetiredAh
Still a good idea to make sure you have an up to date backup if you haven't backed up your data in a while. - Ado1AspirantI have the important stuff on a laptop ;)
But yeah, I need a new NAS for the rest of the data... - Ado1AspirantAny thoughts on the Fan readings on the health page?
- mdgm-ntgrNETGEAR Employee RetiredThat might be related to your OS partition getting full.
Would be interesting to hear if you still have the fan error after an OS Re-install. - Ado1AspirantOk, I will wait for the resync and try a os re-install tomorrow.
Thanks again for all the help.
