Retired_Member
Feb 24, 2018Readynas Ultra 6 freezes
I have a problem with my Ultra 6. (Work on Readynas OS 6) When I defrag my data the nas freeze. I tried everything: - Test disk -> Ok (smart ok for all disk) - Scrub -> Ok - Balance -> Ok I t...
Retired_Member
May 16, 2018When I return home I will look at the smart state, since the first time, 2 of the 6 disks have been changed Factory reset via web ui (System / Settings and then enter "FACTORY" word)
May 16, 2018Guru - Experienced User
System->settings->perform factory default formats all disks and does a fresh factory install. It doesn't let you select specific disks.
If you are using flexraid with multiple volumes, you can destroy a specific volume from system->volume, but you'd have entered DESTROY and not FACTORY.
Can you confirm what you did here?
- Retired_MemberMay 17, 2018
Yes in first time DESTROY volume and next step FACTORY reset.
- Retired_MemberSep 02, 2018
News for my worries
Despite the reset (deletion and re-creation of volume) still the same problem. (Blocking the nas at the time of defragmentation).
(I have done this 3 times)So I tried to isolate a possible defective disk, I created a volume per disk.
I tested defragmenting each volume, and no crash.So I redid a single volume as originally, and there more worries.
It is to understand nothing ????
- StephenBSep 02, 2018Guru - Experienced User
Have you looked at the SMART stats for the disks? You can do this by downloading the log zip file from the web ui, and looking in disk_info.log
All Smart stats are ok no one error.
- StephenBSep 03, 2018Guru - Experienced User
Can you try running the disk test on the volume settings wheel (on each volume)?
- Retired_MemberSep 03, 2018
All volume disk tests were performed without error.
And even now on a single volume
- StephenBSep 04, 2018Guru - Experienced User
Good. I suggest scheduling all the maitenance functions via the volume wheel setting. I run them each once every three months myself.
Let us know if the NAS freezes again.
- Retired_MemberSep 09, 2018
Here is the mainteance of my NAS since the first day that I got it
Maintenance
- StephenBSep 11, 2018Guru - Experienced User
Great, you're already running the maintenance jobs regularly.
- Retired_MemberSep 28, 2018
Return problem, freeze after defrag :-/
- JohnCM_SOct 04, 2018NETGEAR Employee Retired
Hi DevilSilver,
Can you upload the logs to a file sharing site and then PM me the download link?
- Retired_MemberDec 01, 2018
I sent a PM on 2018-11-04 just re-send the pm
Tks
- JohnCM_SDec 21, 2018NETGEAR Employee Retired
Hi DevilSilver,
It seems that the NAS doing file indexing or at least trying to. L3 thinks that somehow the NAS is overloading. You can try turning OFF File Search.
- Jan 17, 2024Retired_Member
