Hibtek
Jul 22, 2014Aspirant
ReadyNAS Ultra 6+ no / mount - Case 23560655
Hi all, I have a problem with my ReadyNAS Ultra 6 Plus, first I lost connection to the device via Windows shares, I thought at one point it was my other computer being stupid, as I could get in to ...
Hibtek
Hi,
Thanks for looking at it, I did say that I moved the photos2-0 folder which was 3.4GB, which cleared up some space on the / partition
This is the mounts.txt from the downloaded logs, can you let me know if its ok
This is the old one from a log file a while ago
/dev/md0 on / type ext2 (rw,noatime,nodiratime)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
tmpfs on /ramfs type ramfs (rw)
tmpfs on /USB type tmpfs (rw,size=16k)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/c/c on /c type ext4 (rw,noatime,nodiratime,acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1)
nfsd on /proc/fs/nfsd type nfsd (rw)
and this is the new one from today
/dev/c/c on /c type ext4 (rw,noatime,acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1)
you can see that this entry is missing
also on my Logs view, the history has gone.
I did not create the Photo2-0 folder on the / but moved it as it was the only big folder on the / I did not recognise
This is from my other ReadyNAS
/c/FTP-Share on /home/ftp/FTP-Share type bind (rw,bind)
is it worth doing a factory reset or an OS reinstall?
