niallryan
Apr 21, 2021Guide
ReadyNas Ultra 6 Plus keeps rebooting randomly
Hi there, I cannot remember if I mention or posted this before, apologies if I did but I am still having the following issues. I have 3 readynas ultra 6's of which one is a plus and is the one with ...
niallryan
Apr 22, 2021Guide
Hi and many thanks for the reply.
I logged into the NAS to make sure everything was ok but in actual fact it was carrying out a re-sync. So it must have restarted during the night - looking at the logs it indeed did - seemingly several times and the NAS was not being used but running in idle. See screenshot of the logs - time is in GMT (0.00)
niallryan
Apr 22, 2021Guide
Apologies meant to add, is it safe to continue with the commands you stated ?
Or is it something else - I have read that people have mentioned a temp sensor failure or indeed a power supply failure.
Regards
- mdgmApr 22, 2021Virtuoso
The command increases the minimum fan speed. It's a safe thing to try.
It could be that a minimum of 800 is too slow a speed for your fan to stay running reliably.To reverse it you can do
# rm /etc/frontview/min_fan_speed_override # systemctl restart readynasd
Note you don't type the #. That's to comment it out as you should think about every command you enter rather than blindly copy and paste.
