Andreas64nl
Jan 11, 2023Aspirant
ReadyNAS Ultra 6 Review (RNDU6000) no network activity???
I have a Netgear ReadyNAS Ultra 6 Review (RNDU6000) that I suddenly couldn't access through my computer last night. The NAS is in my network and is my storage of miscellaneous. It's in a kind of raid...
- Jan 15, 2023
Andreas64nl wrote:How to install OS 6 because I have a ReadyNAS Ultra 6?
I recommend increasing the RAM before you begin. Shipping OS-6 NAS have at least 2 GB of RAM, your ReadyNAS only has 1 GB. It might work, but there have been folks who have run into out-of-memory issues after converting. The upgrade is inexpensive, and is simple to do. If you aren't sure what to purchase, you can open the chassis and examine the RAM that's already installed in order to find something compatible.
Also, if you have the skills, you should probably back up the VPD before conversion. Netgear Mods so far have resolved the VPD problem for users who have run into it, but backing it up would allow you to resolve the issue on your own if you run into it. More information on this is here:
The conversion steps are:
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you do want to update the BIOS it is easiest to do it prior to conversion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
Note that if you ever need to do a USB recovery later on, you will need to use the procedure for 4.2 systems - substituting an OS-6 image for the 4.2.31 one.
Andreas64nl
Jan 14, 2023Aspirant
StephenBTHE username for Frontview is always admin.
I know that.
See this:
I can not reach the NAS via browser and SSH. I can log in via root, via my name but password is not accepted.
Andreas64nl
Jan 15, 2023Aspirant
I can reach Frontview now via this methode: https://www.rensen.nu/faq/ie-modus-in-edge#:~:text=De%20Internet%20Explorer%2Dmodus%20kan,Toestaan%22%20(4)%20zetten. it is in Dutch but the pictures says enough.
I am trying to install EnableRootSSH_1.0.bin but it says the the system has not the right architecture.
- Andreas64nlJan 15, 2023Aspirant
I can install this one ToggleSSH_1.0-x86.bin
After installing ToggleSSH_1.0-x86.bin I have no root acces anymore. Ia, ai, ia
But via Edge under IE I can reach via the browser.
- StephenBJan 15, 2023Guru - Experienced User
Try this one:
Yes, IE mode in Edge will work.
Once you are in, you can install this add-on - which will add TLS 1.2 support to the NAS.
Though IMO converting the NAS to OS-6 is a better strategy, as 4.2.x has not received any security updates since 2017. OS-6 also supports SMB 3, which is helpful as both Microsoft and Apple are deprecating SMB 1.
I think you already know this, but ToggleSSH is the wrong add-on.
