AppLEaDaY
Feb 06, 2025Aspirant
ReadyNAS users and https interface
The NAS is ReadyNas 212 with firmware 6.10.10. Can ordinary users with no particular privilege - the users created to access the shares via SMB - access the https interface and change their passw...
Feb 06, 2025Guru - Experienced User
AppLEaDaY wrote:
Can ordinary users with no particular privilege - the users created to access the shares via SMB - access the https interface and change their password on their own?
Only an admin can change the password on the local NAS accounts.
AppLEaDaY wrote:
Curiously enough if the user belonging to the admin group changes his password, then his credentials don't work anymore: a message is showed telling the account has been locked, due to too many failed attempts and suggesting to re-login after 5 minutes.
Is the PC set up to remember the password? It might be re-applying it.
Keep in mind that the user credential for the NAS does not have to be the same credential used to log into the PC. Since the NAS credential is only used on the local network, it might not need to be changed very often.
Sandshark
Feb 06, 2025Sensei
It's not well documented, but yes you can. Go to https://<NAS IP>/my_password/.
