chsu83
Mar 29, 2017Luminary
ReadyNAS Volume not expanding - with encryption
Don't not the exact Pro 6 Model.. I've got a Pro6 with 2x 2TB and 2x 3TB All worked fine except the XRAID2 isn't working.. at least not how expected. I've installed ReadyNAS OS6 with factor...
- Mar 29, 2017
md1 is the swap volume, so no need to touch that.
If the volume is encrypted, X-RAID won't be able to create sub RAID arrays on unused disk capacity in case of mixed capacity HDDs. It's just not compatible.
This is why the logs say "
Skipping X-RAID auto-expansion on encrypted pool data
Your solutions: use disks of the same capacity, or create separate encrypted volumes, or don't use volume encryption.
chsu83
fdisk -l /dev/sda Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 4AB6C267-7EF1-410C-9DB1-746EFAC1141F Device Start End Sectors Size Type /dev/sda1 64 8388671 8388608 4G Linux RAID /dev/sda2 8388672 9437247 1048576 512M Linux RAID /dev/sda3 9437248 3907029119 3897591872 1.8T Linux RAID
fdisk -l /dev/sdb Disk /dev/sdb: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 14C08FED-6110-48ED-9CB6-E891D3A1E6CC Device Start End Sectors Size Type /dev/sdb1 64 8388671 8388608 4G Linux RAID /dev/sdb2 8388672 9437247 1048576 512M Linux RAID /dev/sdb3 9437248 3907029119 3897591872 1.8T Linux RAID
fdisk -l /dev/sdc Disk /dev/sdc: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 467D1AFA-EEC9-4A6A-BED6-7312DFA34629 Device Start End Sectors Size Type /dev/sdc1 64 8388671 8388608 4G Linux RAID /dev/sdc2 8388672 9437247 1048576 512M Linux RAID /dev/sdc3 9437248 3907029119 3897591872 1.8T Linux RAID
fdisk -l /dev/sdd Disk /dev/sdd: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 0A183F38-CFFF-486A-AA02-81EA4A0D7EC4 Device Start End Sectors Size Type /dev/sdd1 64 8388671 8388608 4G Linux RAID /dev/sdd2 8388672 9437247 1048576 512M Linux RAID /dev/sdd3 9437248 3907029119 3897591872 1.8T Linux RAID
