chsu83
Mar 29, 2017Luminary
ReadyNAS Volume not expanding - with encryption
Don't not the exact Pro 6 Model.. I've got a Pro6 with 2x 2TB and 2x 3TB All worked fine except the XRAID2 isn't working.. at least not how expected. I've installed ReadyNAS OS6 with factor...
- Mar 29, 2017
md1 is the swap volume, so no need to touch that.
If the volume is encrypted, X-RAID won't be able to create sub RAID arrays on unused disk capacity in case of mixed capacity HDDs. It's just not compatible.
This is why the logs say "
Skipping X-RAID auto-expansion on encrypted pool data
Your solutions: use disks of the same capacity, or create separate encrypted volumes, or don't use volume encryption.
chsu83
puh.. it seems like theres something over from the raid6 test :S
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
5845994496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
[>....................] resync = 0.5% (10276820/1948664832) finish=291.4min speed=110830K/sec
md1 : active raid6 sda2[0] sdc2[3] sdd2[2] sdb2[1]
1046528 blocks super 1.2 level 6, 512k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sda1[0] sdc1[2] sdd1[3] sdb1[1]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Tue Mar 28 23:30:15 2017
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Wed Mar 29 21:33:52 2017
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Name : 33eb049b:0 (local to host 33eb049b)
UUID : 73f582d4:eb212081:661a269e:0369cfed
Events : 238
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
3 8 49 2 active sync /dev/sdd1
2 8 33 3 active sync /dev/sdc1
/dev/md/1:
Version : 1.2
Creation Time : Wed Mar 29 00:07:57 2017
Raid Level : raid6
Array Size : 1046528 (1022.00 MiB 1071.64 MB)
Used Dev Size : 523264 (511.00 MiB 535.82 MB)
Raid Devices : 4
Total Devices : 4
Update Time : Wed Mar 29 00:29:12 2017
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 512K
Name : 33eb049b:1 (local to host 33eb049b)
UUID : 8af43a31:0aabdd5a:7cbd7294:fc716ca5
Events : 20
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 8 50 2 active sync /dev/sdd2
3 8 34 3 active sync /dev/sdc2
/dev/md/data-0:
Version : 1.2
Creation Time : Wed Mar 29 07:48:01 2017
Raid Level : raid5
Array Size : 5845994496 (5575.17 GiB 5986.30 GB)
Used Dev Size : 1948664832 (1858.39 GiB 1995.43 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Wed Mar 29 21:32:46 2017
State : clean, resyncing
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Resync Status : 0% complete
Name : 33eb049b:data-0 (local to host 33eb049b)
UUID : b8e3be8c:5c3f556b:90d6189c:4a27892f
Events : 134
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3
