chsu83
Mar 29, 2017Luminary
ReadyNAS Volume not expanding - with encryption
Don't not the exact Pro 6 Model.. I've got a Pro6 with 2x 2TB and 2x 3TB All worked fine except the XRAID2 isn't working.. at least not how expected. I've installed ReadyNAS OS6 with factor...
- Mar 29, 2017
md1 is the swap volume, so no need to touch that.
If the volume is encrypted, X-RAID won't be able to create sub RAID arrays on unused disk capacity in case of mixed capacity HDDs. It's just not compatible.
This is why the logs say "
Skipping X-RAID auto-expansion on encrypted pool data
Your solutions: use disks of the same capacity, or create separate encrypted volumes, or don't use volume encryption.
chsu83
Have done:
mdadm --grow /dev/md/1 --level=raid5
mdadm --grow /dev/md/1 --raid-devices=4
rebooted
but have
in LOG
chsu83
seems perhaps expanding doesn't work.. at least for uneven devices.
But this seems like it should work:
https://community.netgear.com/t5/Using-your-ReadyNAS/Setting-up-encryption/td-p/841686
ok that seems a statement:
https://community.netgear.com/t5/Using-your-ReadyNAS/X-RAID-expansion-on-Pro4-with-OS6/td-p/904490
are there any newer knowings?
