chsu83
Mar 29, 2017Luminary
ReadyNAS Volume not expanding - with encryption
Don't not the exact Pro 6 Model.. I've got a Pro6 with 2x 2TB and 2x 3TB All worked fine except the XRAID2 isn't working.. at least not how expected. I've installed ReadyNAS OS6 with factor...
- Mar 29, 2017
md1 is the swap volume, so no need to touch that.
If the volume is encrypted, X-RAID won't be able to create sub RAID arrays on unused disk capacity in case of mixed capacity HDDs. It's just not compatible.
This is why the logs say "
Skipping X-RAID auto-expansion on encrypted pool data
Your solutions: use disks of the same capacity, or create separate encrypted volumes, or don't use volume encryption.
chsu83
Have done:
mdadm --grow /dev/md/1 --level=raid5
mdadm --grow /dev/md/1 --raid-devices=4
rebooted
but have
in LOG
jak0lantash
Mar 29, 2017Mentor
- chsu83Mar 29, 2017Luminary
thank you for that.. good to know.
yep.. the swap I only touched because I thougt if something is checking raid level of different raids.. and only if all ar good and in same way configured then the expansion starts.. thats why I tried to make them similiar.
The statement, I've seen later :)
So then.. cool feature.. personally I think its a cool implementation of it. Would perhaps be great for some situation, that there is a mini webservice to submit the key in the boot process without a key. Unfortunately this situation I couldn't thest via the VM, because I didn't now how to propagate the USB Stick.
Perhaps some time the possibility will come use XRAID with uneven disks and encryption. Or enabling/disabling encryption after creation of the volume..
*hoping*
Thanks to all of you, made the OS6 possible on legacy devices.
I'll have to think to destroy the volume, or buy new Harddisks.. :S - bad situation, if you got enough place with the cool XRAID :)
- jak0lantashMar 29, 2017Mentor
chsu83 wrote:Would perhaps be great for some situation, that there is a mini webservice to submit the key in the boot process without a key.
If you wish to suggest a new feature, you should post it in the "Idea" section. That way people can vote for it if they want to.
