NAStastic
Dec 07, 2014Aspirant
Readynas X6 led patterns
Greetings, I've got an old Infrant ReadyNAS X6-TL (3.01c1-p6). Upon startup I find that LEDs 1 & 2 will light solid, then go dark alternating with lights 3 & 4. (1 and 2 on/3 and 4 off, 3 and 4 on/1...
vandermerwe
Dec 07, 2014Master
It looks like it could indicate a memory problem:
http://www.readynas.com/download/docume ... S-LEDA.pdf
What firmware are you running?
Do you have a backup? Presumably yes if you've recent reset it.
You could run a memory test via the boot menu.
