NAStastic
Dec 07, 2014Aspirant
Readynas X6 led patterns
Greetings, I've got an old Infrant ReadyNAS X6-TL (3.01c1-p6). Upon startup I find that LEDs 1 & 2 will light solid, then go dark alternating with lights 3 & 4. (1 and 2 on/3 and 4 off, 3 and 4 on/1...
NAStastic
Dec 09, 2014Aspirant
DIMM troubleshooting:
> I tried reseating the current 1 GB DIMM however the issue persists.
> I also tried using the original 256MB DIMM which shipped with the unit and I observed the same issue (I upgraded several years ago)
What firmware are you running?
> RAIDiator™ v3.01c1-p6 [1.00a034]
Do you have a backup? Presumably yes if you've recent reset it.
> Yes, I have a backup
You could run a memory test via the boot menu.
> As described in the LED Language document you provided I held the power switch for 25 seconds and after the 5th "all disk LED blink" I let go of the switch. Disk LED lights 1-4 illuminated individually while the power LED fast blinked. At present all 4 disk LEDs are illuminated solid while the power LED continues to fast blink. The NAS however is not located with a RAIDar scan and is inaccessible.
