BubbaB808
May 11, 2020Tutor
ReadyNAS214 not shutting down after firmware update
I just did a firmware update to 6.10.3 for a ReadyNAS214 and now when I power it down, the display indicates do_exit+4d8 and it doesn't turn off. My only option is to pull the power plug out, but th...
- May 16, 2020
Hi BubbaB808,
As discussed over the private message, you may try turning On the Wake On LAN then turn it Off again if you encounter that LCD error when the NAS is shutting down.
BubbaB808
May 12, 2020Tutor
John, not too sure on how to do that. Can you provide the location and steps for me to do this? Thanks.
JohnCM_S
May 16, 2020NETGEAR Employee Retired
Hi BubbaB808,
