wheelhouse20's avatar
wheelhouse20
Readys NAS nv+ destroys my hard drives
i have 2x1.5tb and 2x2tb hard dirves which i set the nas to erase so i let it do the job and when i can back to it
it sayed it had been done but for some reason only 1 of my hard drives is usable and i cant read nor format the other 3
nas says there bad but i hung then in a Linux system which says there are healthy.
  • i did factory reset with the one good hard drive in each of the nas bays all installed without any issues
  • wheelhouse20 wrote:
    i didn't get any notifications regarding HDD failures also none of the disk diagnostic tools picked up my hard drives
    2x1.5tb HD154UI
    2x2tb WD20EZRX
    So the nas will work normally as long as you use only a certain one of the original disks, and you were unable to get vendor tools to recognise any of the other 3 original disks?
    It seems unlikely , but perhaps all 3 of the other disks are in fact, as the nas has suggested, bad.
ProSupport for Business
