dmworking247
Oct 03, 2014Aspirant
Recommend a newer model of a Netgear NAS?
Hi all, After some recurring problems with my ReadyNAS DUO v1 (related to the system partition filling up with a log file and rendering the unit unusable until tech support bails me out), which the...
mdgm-ntgr
Oct 03, 2014NETGEAR Employee Retired
ReadyNAS OS, especially firmware 6.1.9 onwards is very good at rotating log files to avoid filling the OS partition with them.
Also the OS partition is 4GB which is twice the size of the 2GB one on your Duo.
You are more likely to be able to install things such as mine craft on an x86 box such as the 312 than an ARM box such as the 102.
