dmworking247
Oct 03, 2014Aspirant
Recommend a newer model of a Netgear NAS?
Hi all, After some recurring problems with my ReadyNAS DUO v1 (related to the system partition filling up with a log file and rendering the unit unusable until tech support bails me out), which the...
xeltros
Oct 04, 2014Apprentice
I disagree for the logs on the data partition as things are likely to go wrong on the OS partition before ; And when there is no data to recover you just factory default anyway.
Other problems could be addressed individually too, though they will require SSH and a certain amount of knowledge. That's the beauty of linux, but I agree that messing with a NAS is not the best idea in the world and that it would require time too.
I don't think OS6 devices will have such problems as :
1- Netgear probably implemented a better log rotate mechanism
2- BTRFS is easy to resize (though I think ARM devices use an ext4 OS partition)
Another advantage to take the 300 series over the 100 series is that (I think) it is covered by lifetime assistance (not hardware though hardware warranty should be longer than on the 1xx series too).
