dmworking247
Oct 03, 2014Aspirant
Recommend a newer model of a Netgear NAS?
Hi all, After some recurring problems with my ReadyNAS DUO v1 (related to the system partition filling up with a log file and rendering the unit unusable until tech support bails me out), which the...
Oct 04, 2014Guru - Experienced User
In my experience data volume failures are more frequent than OS partition problems. And operationally there are times when the data volume doesn't exist (or hasn't yet been mounted). Support can deal with some data volume problems w/o a reset, but I'm sure the logs help them diagnose when that can/can't be done.
xeltros wrote: I disagree for the logs on the data partition as things are likely to go wrong on the OS partition before ; And when there is no data to recover you just factory default anyway.
Anyway, we are off-topic.
