digitaldentistr
Mar 30, 2015Aspirant
Recommended ReadyNAS Implementation with Redundancy
I'm looking to build redundancy between two NAS devices on a local network. My use for the ReadyNAS is to completely separate data which is currently around 500GB and growing at 100GB a year from the...
digitaldentistr
Apr 08, 2015Aspirant
I was looking over the replicate feature and it says
"Backup data or replicate the entire device
ReadyNAS Replicate gives you the option to backup a selected folder on the ReadyNAS, or backup/replicate the entire ReadyNAS. The replication support captures all the configuration settings on your ReadyNAS so that you can replicate the primary ReadyNAS environment just by doing a simple system restore."
The above says that it can replicate the entire unit including it's configuration. So why can't I just do a restore on the second NAS in case of a failure of primary NAS?
