sdfjibsdf
Oct 20, 2022Aspirant
"Recover" grayed out in Shares
A folder in shares I'm seeking to "recover" to a computer on my wired Win10 network is grayed out. I would be able to download individual files from this folder, but I need to recover the entire fol...
- Oct 25, 2022
sdfjibsdf wrote:
I can't use Win Explorer to copy or transfer files from NAS to a networked computer.
Why not?
Have you tried entering \\nas-name or \\nas-ip-address in the explorer address bar? (use the real hostname or IP address of course, and be careful to use the correct slash direction).
Oct 20, 2022Guru - Experienced User
Try going to the "file access" tab for the share. Click on "reset", and then "reset permissions". See if that solves it.
When you say "recover", do you just mean "copy"?
sdfjibsdf
Oct 23, 2022Aspirant
Resetting the permissions under the File Access tab didn't work. And actually a few of my folders have the "recover" grayed out.
And yes, I'm trying to move the NAS files and directories onto a new computer on my network.
- sdfjibsdfOct 23, 2022Aspirant
and here's another potentially relevant ss
- StephenBOct 23, 2022Guru - Experienced User
Can you post of screen shot on where you are looking for "Recover". I am wondering if you are confusing copying files with the NAS snapshot recovery feature.
- sdfjibsdfOct 24, 2022Aspirant
- StephenBOct 24, 2022Guru - Experienced User
"recover" on this screen is about snapshot recovery.
Using this feature will roll back your share contents to the snapshot you select. It will not transfer any data to or from your PC.
Ah. OK. How do I xfer from NAS to my computer?
