steveoelliott's avatar
Dec 13, 2016
Remote access for Netgear Support
Hi,   This is a question for the Netgear folks really but I was wondering whether the Netgear support team would connect to a device via SSH or HTTPS if the user / customer provided connection deta...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Dec 13, 2016
    We have a Secure Diagnostics Mode that can be enabled if the http/s service is running. We've configured a safe mode fallback so the https service should remain running unless there is a crash or it was forced off by an Out of Memory condition (OOM is caused by a memory leak - a process uses too much memory so the system has no choice but to forcibly shutdown processes). This is preferable to tech support mode in most cases.
    For some problems you do need the system to be running normally to diagnose effectively.
    Secure Diagnostics Mode can be enabled even if the management service is offline unless you're still running ancient 6.1.8 or earlier firmware (which you shouldn't be).
    On 6.1.x and earlier Secure Diagnostics Mode was called Remote Access SSH. Some users didn't seem to realise this was SSH for support only so we renamed it to something a bit more obvious.
    Tech support mode is a low level diagnostic mode useful for diagnosing a wide range of problems. In tech support mode the RAID has to be manually started, the OS and volume manually mounted etc. For some problems tech support mode is necessary.
    On older ReadyNAS we have the Remote Access SSH add-on as an alternative to tech support mode.
ProSupport for Business
