darkmarauder
May 23, 2013Aspirant
Remote Wake on Lan
Hello,
I have a Readynas Duo v2, with the latest firmware (as of 23/05/13) and latest version of Raidar.
I have successfully got a wakeonlan tool (sadly called wakeonlan, from Aquila Tech) to wake up my NAS whilst I am attached to my local network.
I have installed and successfully tested ReadyNas Remote whilst on my local network too.
I do already use the auto power on/off during the night to make backups of my NAS contents, and do not want it left on at all times.
So, my question is can I remote wake up my ReadyNAS from another location?
If so, how?
If so, how?
- darkmarauderAspirantBUMP :-)
- doylmiGuideYes, but depending on your router set up, it might not be that straightforward. Here is a pretty good tutorial. It's from DD-WRT, but the principals apply in a broader sense.
http://www.dd-wrt.com/wiki/index.php/WOL
Some "home" routers do not allow port forwarding to the broadcast address, so your mileage may vary. - Please check if you can run DD-WRT or Tomato firmware on your router ...
This will be one of your solution.
Here is DD-WRT database (http://dd-wrt.com/site/support/router-database) - darkmarauderAspirantOK, I have already set up Port forwarding, which I would have expected to be working as I am able to use WOL from within my LAN.
Anyway, I will follow the instructions given.
One question though, is how do I test access to the Readynas from outside my LAN?
I would have expected something like http://INTERNETIPADDRESS/readynas etc etc - StephenBGuru - Experienced User
That simply does not follow. Everything is open on the local LAN, by default all unsolicited inbound internet traffic is blocked by the router firewall . Port forwarding changes that behavior for the specified port. In general it can create some security vulnerabilities, and many routers therefore limit what they will forward to protect the users from themselves. ISPs will also often block some ports for similar reasons.darkmarauder wrote: OK, I have already set up Port forwarding, which I would have expected to be working as I am able to use WOL from within my LAN.
More port forwarding (setting up a second HTTPS port number on the NAS, and forwarding that port in the router to the NAS). Then you would use https://INTERNETIPADDRESS:PORT/admindarkmarauder wrote: One question though, is how do I test access to the Readynas from outside my LAN?
After the test look into dynamic DDNS, which would give you a name that you can use instead of the IP address. Your ISP will change your IP address w/o notice, so it is best to use a name that is always linked to whatever your current IP address assignment happens to be.
