theluke79
Jan 10, 2015Aspirant
Rename Volume RN102 JBOD
Hi! i have a RN102 fw 6.2.2 2 Disks: 2TB & 3TB No SCSI is configured, just JBOD, the volumes are "indipendent". I want to change the names of the 2 volumes, how can I do it? Seems impos...
mdgm-ntgr
Jan 10, 2015NETGEAR Employee Retired
Renaming existing volumes is not something we support.
You could backup your data, delete the volumes (note all data on a volume is lost when you delete it so you must backup your data first), create new volumes and restore your data from backup.
