gregb_pro
Aug 21, 2015Aspirant
Replacement procedure for suspect drive in ReadyNAS Pro BE
BACKGROUND: ReadyNAS Pro Business Edition with six WD 750 GB enterprise drives (WDC WD7502ABYS-01A6B0), all drives with 03.00C05 firmware. The drives show about 57,000 runtime hours (about 6.5 years...
Aug 21, 2015Guru - Experienced User
I always recommend a hot-swap - because it ensures that the NAS will detect the removal and insertion. However, a cold insertion of an unformatted disk should also work.
I'd also replace the drive now, I see no reason to wait.
You might want to run Western Digital's Lifeguard diag on the replacement first (that is a windows application, available on the WDC web site). That's just to make sure nothing happened while the drive was on the shelf.
- gregb_proAug 28, 2015Aspirant
Suspect drive #2 was removed as suggested (system up). Unfortunately, the "noise" did not subside with removal of the drive. Tested the drive with WD Lifeguard Diagnostic for Windows (v1.24) and wrote zeros to drive (full test, full zero). Re-installed drive back into ReadyNAS, and the system rebuilt back to X-RAID2 as expected. ReadyNAS log:
Sun Aug 23 08:40:34 MDT 2015 Disk removal detected. [Disk 2] Sun Aug 23 08:40:35 MDT 2015 A disk was removed from the ReadyNAS. For [...] Sun Aug 23 08:40:42 MDT 2015 Disk failure detected. Sun Aug 23 08:40:42 MDT 2015 If the failed disk is used in a RAID level [...] Sun Aug 23 13:42:02 MDT 2015 New disk detected. If multiple disks have [...] Sun Aug 23 13:44:13 MDT 2015 Data volume will be rebuilt with disk 2. Sun Aug 23 13:44:35 MDT 2015 RAID sync started on volume C. Sun Aug 23 17:47:19 MDT 2015 RAID sync finished on volume C.
System appeared to run well for 5 days.
Still trying to diagnose noise source. Remove suspect drive from bay 1 while system up:
Fri Aug 28 07:36:55 MDT 2015 Disk removal detected. [Disk 1] Fri Aug 28 07:36:55 MDT 2015 A disk was removed from the ReadyNAS. Fri Aug 28 07:37:21 MDT 2015 Disk failure detected. Fri Aug 28 07:37:21 MDT 2015 If the failed disk is used in a RAID level [...]
Test and zero new zero-hour drive with WD Lifeguard Diagnostic for Windows (v1.24). Passed.
Test and zero old drive #1 with WD Lifeguard Diagnostic for Windows (v1.24). Passed.
Insert *new* drive into bay 1; surprisingly it FAILED SMART test: Arrgh!Fri Aug 28 14:42:28 MDT 2015 New disk detected. If multiple disks have been [...] Fri Aug 28 14:42:41 MDT 2015 Newly added disk has failed SMART test. Please check disk 1.
Remove new drive from bay 1, then
Insert old drive into bay 1; it also FAILED SMART test:Fri Aug 28 14:55:12 MDT 2015 Disk removal detected. [Disk 1] Fri Aug 28 14:55:12 MDT 2015 A disk was removed from the ReadyNAS. For full [...] Fri Aug 28 14:59:51 MDT 2015 New disk detected. If multiple disks have been [...] Fri Aug 28 15:00:04 MDT 2015 Newly added disk has failed SMART test. Please check disk 1.
Remove old drive from bay 1; then
Test and quick zero old drive with WD Lifeguard Diagnostic (Passed);
Shutdown and reboot; then
Insert old drive into bay 1; it also FAILED SMART test:Fri Aug 28 15:06:55 MDT 2015 Disk removal detected. [Disk 1] Fri Aug 28 15:06:55 MDT 2015 A disk was removed from the ReadyNAS. For full [...] Fri Aug 28 15:08:30 MDT 2015 Please close this browser session and use RAIDar [...] Fri Aug 28 15:09:47 MDT 2015 System is up. Fri Aug 28 15:19:16 MDT 2015 New disk detected. If multiple disks have been [...] Fri Aug 28 15:19:27 MDT 2015 Newly added disk has failed SMART test. Please check disk 1.
So, bay 1 failed two successive SMART tests (two different drives), and failed again after a reboot.
Both drives pass WD Lifeguard Diagnostic (one is zero-hour drive).
Looking for recommendations.
Thanks, gregb
- gregb_proAug 29, 2015Aspirant
Tested drives again with WD Lifeguard Diagnostic for Windows; both show PASS.
Both drives show no SMART issues (all zero's in expected warning indicators).
Does RAIDiator 4.2.27 keep an internal database of drives and serial numbers with capability to reject drives based on database history? (although neither of these drives are actually failed).
Thanks, gregb
- gregb_proAug 31, 2015Aspirant
I am still looking for a solution to return the device back to 6 active drives (X-RAID2).
WD Lifeguard Diagnostic shows two good replacement drives: one drive with 57K hours and one new drive.
Both pass WD Lifeguard Diagnostic tests, both have zeros written to all blocks, both show good SMART data.
However, for both drives, ReadyNAS Frontview status indicates "Newly added disk has failed SMART test" when inserting into bay 1 (as noted in previous posts). The "failed SMARTtest" message doesn't show up in system.log.Old drive:
Raw Read Error Rate 0 Spin Up Time 1133 Start Stop Count 29 Reallocated Sector Count 0 Seek Error Rate 0 Power On Hours 57150 Spin Retry Count 0 Calibration Retry Count 0 Power Cycle Count 27 Power-Off Retract Count 10 Load Cycle Count 29 Temperature Celsius 43 Reallocated Event Count 0 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Multi Zone Error Rate 0 ATA Error Count 0
New drive:
Raw Read Error Rate 0 Spin Up Time 1200 Start Stop Count 8 Reallocated Sector Count 0 Seek Error Rate 0 Power On Hours 140 Spin Retry Count 0 Calibration Retry Count 0 Power Cycle Count 6 Power-Off Retract Count 5 Load Cycle Count 8 Temperature Celsius 33 Reallocated Event Count 0 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Multi Zone Error Rate 0 ATA Error Count 0
Thanks, gregb
