nyCecilia
Jun 24, 2020Aspirant
Restriping, 120 hours?
Hi all, I know my Pro Pioneer is ancient and I hope to replace it soon. But in the meantime I replaced a drive and it is now restriping. I know that it takes a while to restripe, but is 120 hours ...
Jun 24, 2020Guru - Experienced User
nyCecilia wrote:
I know that it takes a while to restripe, but is 120 hours correct? I remember it taking half a day, but I don't recall it being 120 hours. What do you think is going wrong?
How long has it actually been running? The estimated completion times aren't very accurate, so if the disks are healthy then it likely will complete faster than that.
But it is possible that another disk isn't healthy. So I suggest looking at the smart stats. If you download the full log zip file, you will find them in disk_smart.log. You can download them again in a few hours, and compare them. If you are running 4.2.x firmware, you can also look in the on-screen log - reallocated or pending sectors, and timeouts should be in there.
- nyCeciliaJun 24, 2020Aspirant
Thanks for the reply. I have four disks total, one which I replaced yesterday afternoon and it's now at 15%, but saying 115 hours, but it's really been closer to 12 at this point, so I guess that's off. The other three disks are showing healthy, one at 41k hours and the other two at 15k hours. Reallocated sectors is 0 for the three disks (obviously I can't see the new disk).
Guess I'm just going to cross my fingers for now. At least I have a backup.
- StephenBJun 24, 2020Guru - Experienced User
What disks are you using (including the new one)?
They're all WD/EFRX drives, all red. Before replacing, I had 2 2tb drives (from ~2013?) and 2 3tb drives (2017?). Yesterday I swapped a 2tb for a 4tb drive. Knowing that the 2tbs were older, I wanted to be prepared so last year I bought 2 4tb drives with the intention of replacing both 2tb drives, and I'm finally getting around to it. I've only been using this machine for file backup/storage (edit: and Sonos), but for that purpose it's mostly been trouble free, so I don't think about it a lot.
