jchappy65
Oct 04, 2011Aspirant
resurrecting a RNV2-S2-0000
I found an old RNV2-S2-0000 that a co-worker was throwing out, and I was wanting to reuse it. bad thing is that it was only the box. I would like to know if I could buy the lockable trays for it? also...
jchappy65
Apr 18, 2012Aspirant
Thank you so much, Will do. It says "Booting... Checking root FS" at the moment I'm guessing because of the Firmware update....
EDIT: I followed the directions to perform a Factory Default reset (Holding in the Reset button on the back of the console for 30 seconds) and two LED flashes are supposed to happen, but they dont, and when I powered the NAS back on, it booted up normal, but after 5 minutes just idling it flashed for 3 seconds, "Vol C is dead" then went back to normal
